Program Scheduler
Re: Program Scheduler
I understand; but as said, ProppFrexx doesn't automatically create new program entries by itself (the gray ones).
Please give me some time to look at your calendar file...
rockdj
Post by rockdj »
Thank you. I hope you can help me out :P
rockfiles.nl 110% rock radio!!
the no.1 rock & metal station!!
So I checked you calendar (program scheduler)!
You have create a daily recurring program called "dag-even" from 10:00:00 - 10:58:00 and another daily recurring program called "dag-oneven" from 11:00:00 - 11:58:00.
I just deleted the entire series and they disappeared!
(I selected the "dag-even" with the mouse, pressed the DEL key and when asked I selected 'Delete the entire series' - same with the "dag-oneven" entry)
Once I deleted them, they never re-appeared here.
Did you probably only delete one occurrence, but not the whole series?
Then I had to go to the 16th of November and did the same, as here someone has created another set of daily recurring entries.
So there was NO bug, NO nothing; someone just created many parallel daily recurring entries ;-)
I'll send you the modified calendar file back via eMail.
rockdj
Post by rockdj »
I replaced the file. And the problem is solved!! Thank you very much :D
