History check
Jeroen R
Re: History check
Post by Jeroen R »
with the first track with USE HOOK point I can not do anything else than suppress History check and suppress add history
Then with the HOOKQUEUE only suppress history check.
Only in this way the hooks play and then also as a complete track.
Is it possible to also set some history with the first track with the CUE HOOK POINT? If I do not suppress the history, the correct track does not play completely.
Re: History check
I assume you are doing something wrong or have too many histories involved.
In my tests it just works fine as I described it above. I can not reproduce your issue.
What do you mean by „does not play completely“? Is it played only half?
All what you ask is working as expected. Have you tried my example above? Please send a screenshot of you script. And really try what I explained above. And what is not working in that case?
Jeroen R
Re: History check
Post by Jeroen R »
indeed... I did something wrong with the history settings....
I am glad that the hooks are also chosen with history. Yes now this works fine. Very good, thanks for the help.
