v3.0.11.15 - stable
Re: v3.0.11.15 - stable
I don't really think so, as the StopWatch or Countdown is really more a popup window (like a dialog) - as it will e.g. be closed automatically e.g. once the CountDown is reached.
If you would dock that, it would be docked/undocked each time it is invoked or closed...that might give the user even more confusion I guess.
dokos
Post by dokos »
system is unstable after the update. After a few songs that I'm working on it crashes. It's quite annoying when you send and the silence ...
Marian
dokos
Post by dokos »
I have already done so. and then it crashed and history from yesterday is gone too. When the system goes alone to nehavaruje. But if I attach a remake of a song as well as a 2 hour crash.
dokos
Post by dokos »
I could not find any log file today. But I changed my big font to normal and disable auto update segue editor. Currently it works.
szal77
Post by szal77 »
Related? ?
Fehlerbucket 3240106446, Typ 1
Ereignisname: APPCRASH
Antwort: Nicht verfügbar
CAB-Datei-ID: 0
Problemsignatur:
P1: ProppFrexx ONAIR.exe
P2: 3.0.11.15
P3: 5097b1c6
P4: BASSMIX.dll
P5: 2.4.7.3
P6: 504dddc0
P7: c0000005
P8: 00004527
P9:
P10:
Angefügte Dateien:
C:\Users\szal\AppData\Local\Temp\WER4B29.tmp.WERInternalMetadata.xml
Diese Dateien befinden sich möglicherweise hier:
C:\Users\szal\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_ProppFrexx ONAIR_498f149150b45136ac90f872167bcdb28e4ad28_0483644e
Analysesymbol:
Es wird erneut nach einer Lösung gesucht: 0
Berichts-ID: 25b1851e-28d9-11e2-9fb3-0016416b25ea
Berichtstatus: 0
Was the 3rd time today that I got this, with read-ahead cache disabled. ProppFrexx just hung and a requester came up telling me that PFOA stopped working, giving me the choice to either research the problem online or close PFOA. In all 3 cases this happend on track change, or rather when one track finished playing—this last one happened at the end of a playlist.
szal77
Post by szal77 »
Thank you; just wanted to know whether this is the same or something different.
JonyKanal80
Post by JonyKanal80 »
radio42 wrote:We are already working on this bug - which appears to be in the audio engine I am using.
If nothing helps, please revert to v3.0.11.12:
Download the zip file from the below link and install it manually:
http://www.proppfrexx.radio42.com/downl ... 301112.zip
To do so:
- close any ProppFrexx application
- make a backup of your ProppFrexx installation folder (e.g. C:\Program Files (x86)\radio42\ProppFrexx ONAIR\3.0)
- unzip the zip content to your ProppFrexx installation folder
- this should overwrite all existing files in there
- restart ProppFrexx ONAIR
Let me know, if that solved your issue.
THX
Bernd
Download Link is incomplete.....
http://www.radiocanal80.com
The Best 80's & 90's Music
Yes, that is exactly the same bug as already reported.
As explained above, revert to v3.0.11.12 in such case - we are already working with the developers of the audio lib to get this fixed asap!
Please see the above post:
It seems to related to the new look-ahead cache reading feature.
You might disable this new feature in the general settings - section 'General/Audio' and set the 'Lookahead Cache' value to 0 (zero)!
Then v3.0.11.15 should run stable.
Are there any errors in the "Error.log" file or the Windoes event log?
