Weather pannel in control room
louis
Re: Weather pannel in control room
Post by louis »
I hope you are having a wonderful 2014 thus far.
My weather panel shows an incorrect temperature. Both Celsius and Fahrenheit seem to be incorrect, showing temperatures around 250 degrees.
Though I'd prefer it to be a bit warmer than the negative temperatures of this polar vortex, I don't think my equipment would much like temps quite that high ;-)
Mine is okay here.
However, what location name are you using?
In any case, the weather data is provided by www.OpenWeatherMap.org any may be the data is just provided incorrectly by them?
You might want to double check this directly with them...
louis
Post by louis »
http://www.openweathermap.org/city/5000947
Looks right on their page...
Ahh, I guess you are using 'Fahrenheit' as the display unit?!
Seems, that the API has slightly changed here and I need to update it...as they now also introduced an 'Internal' measurement unit...which is now the default (instead of the local unit as before).
As such this issue came up.
It will be fixed in the next version!
