Little probleem with Touch osc
Re: Little probleem with Touch osc
I have provided a new v4.5.2.9-beta - so please "Check for Beta-Versions..." to update.
And don't forget to remove the 'async' line above from the two events.
robbedoeske
Post by robbedoeske »
Oke wil try later today;)
robbedoeske
Beta version works perfectly Bernd, many thanks for this quick solution
