Setup Cartwall Lights on Control Module of D&R Airence MK2
Re: Setup Cartwall Lights on Control Module of D&R Airence MK2
The command with the param 255|0 disables all LEDs.
Not only the ones of the 1st or 2bd row (at that time I didn’t know, that you want to use both cartwalls).
As there is no command for the mixer to disable only a specific row. You must replace that command with multiple commands to disable the specific row.
Eg call:
EXEC_SEND_DRAIRENCE_SETLED 1|0
EXEC_SEND_DRAIRENCE_SETLED 3|0
EXEC_SEND_DRAIRENCE_SETLED 5|0
respectively
EXEC_SEND_DRAIRENCE_SETLED 2|0
EXEC_SEND_DRAIRENCE_SETLED 4|0
EXEC_SEND_DRAIRENCE_SETLED 6|0
Knarrenheinz
Post by Knarrenheinz »
I have removed the command EXEC_SEND_DRAIRENCE_SETLED 255|0 from the OnCartwall1Changed and OnCartwall2Changed.
And added all the commands for each button in cartwall 1 and cartwall 2 like you suggested.
The first row (cartwall 1) is working fine. Here is an example.
Load a jingle library with 3 jingles -> light 1, 2 and 3 from the first row light up.
Load a new jingle library with 7 jingles -> light 1, 2, 3, 4, 5, 6 and 7 from the first row light up.
Load again the jingle library with 3 jingles -> light 1, 2 and 3 light up and 4, 5, 6 and 7 go out.
Unload the first cartwall (set it to none) -> all the lights go out.
The second row (cartwall 2) is unfortunately not working this way.
Load again the jingle library with 3 jingles -> light 1, 2, 3, 4, 5, 6, and 7 stay on and do not go out.
Unload the second cartwall (set it to none) -> all the lights from 1 to 7 stay lighted. The jingle libraries in the second cart from ProppFrexx itself change to the correct one. Only the lights on the mixer don’t respond. I have to disconnect the connection in the GPIO-Client to put out the lights.
All settings look the same to me, except for the button numbering of course.
Here is what I have setup right now.
OnCartwall1Play
EXEC_SEND_DRAIRENCE_SETLEDBLINK *[TOINT:{${cartid}}:{vert}:{8}:{2}]|1|0|1
OnCartwall1Pause
EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert}:{8}:{2}]|2
OnCartwall1Changed
EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 1|2
EXEC_COMMAND2 ${cw1cart2trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 3|2
EXEC_COMMAND2 ${cw1cart3trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 5|2
EXEC_COMMAND2 ${cw1cart4trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 7|2
EXEC_COMMAND2 ${cw1cart5trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 9|2
EXEC_COMMAND2 ${cw1cart6trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 11|2
EXEC_COMMAND2 ${cw1cart7trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 13|2
EXEC_SEND_DRAIRENCE_SETLED 7|0
EXEC_SEND_DRAIRENCE_SETLED 9|0
EXEC_SEND_DRAIRENCE_SETLED 11|0
EXEC_SEND_DRAIRENCE_SETLED 13|0
OnCartwall2Play
EXEC_SEND_DRAIRENCE_SETLEDBLINK *[TOINT:{${cartid}}:{vert2}:{8}:{2}]|1|0|1
OnCartwall2Pause
EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert2}:{8}:{2}]|2
OnCartwall2Changed
EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 2|2
EXEC_COMMAND2 ${cw2cart2trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 4|2
EXEC_COMMAND2 ${cw2cart3trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 6|2
EXEC_COMMAND2 ${cw2cart4trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 8|2
EXEC_COMMAND2 ${cw2cart5trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 10|2
EXEC_COMMAND2 ${cw2cart6trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 12|2
EXEC_COMMAND2 ${cw2cart7trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 14|2
EXEC_SEND_DRAIRENCE_SETLED 8|0
EXEC_SEND_DRAIRENCE_SETLED 10|0
EXEC_SEND_DRAIRENCE_SETLED 12|0
EXEC_SEND_DRAIRENCE_SETLED 14|0
In the OnCartwallChanged I also tried putting the EXEC_SEND_AIRENCE_SETLED xx|0 command's before the EXEC_COMMAND2... command's, but then all (7) buttons light up no matter how many jingles you load into cartwall 1 and 2.
Yes. You should put the LED off command (EXEC_SEND_AIRENCE_SETLED xx|0) before the conditional command in the on cartwall changed event.
And put the ASYNC command on top.
Knarrenheinz
Unfortunately, the “ASYNC” on top doesn’t give the result I am looking for.
Every time when you load a jingle library into the ProppFrexx cartwall 1 or cartwall 2, it lights up all the 7 buttons I have setup. Even when there are only 3 or 4 jingles in that library. When I unload the cartwalls the lights now all go out, unlike yesterday when I didn’t have the ASYNC command added on top of the command list.
I’ve tried a few other combinations but none of them give me the wanted result.
I guess I see your issue - it is 'just' a timing issue, as it could be, that the loading of the single cart entries might take a little longer...(note, that all is processed async to not block any operations).
I.e. just change the OnCartwallChanged event to this:
ASYNC
SLEEP 300
The sleep command will just wait a little to make sure, that the cart entries have finally be loaded. If you still experience issues, you might increase the sleep to maybe 500 milliseconds.
Knarrenheinz
Unfortunately it didn't do the trick.
Nothing changed. All the buttons are keep lighting up. Of course slower as normal, because of the SLEEP xxx command.
I tested it with the simulator of D&R and it was working perfectly fine. So if it is not working with a real mixer, the issue must be somewhere at D&R.
You have surely added the code exactly as given above?
And even tried to increase the sleep time to eg. 500ms?
I am wondering, why all buttons keep lighting up?
And slower is relative, as you of course would have to wait until all carts are loaded - which takes half a second - I being honest don’t really recognize it, unless you explicitly wait for it.
Knarrenheinz
Yeah, I also thought that you nailed it down with your previous post.
According to myself, I entered everything like it should be with your fantastic help.
I tried different SLEEP times: 300, 500, 750, 1000 and 2000 as maximum. All with the same end result. All 7 buttons per cart light up, even when there are only 2,3 or 4 jingles in it.
Here is my D&R Airence events file.
<configuration>
  <configSections>
    <sectionGroup name="ProppFrexx">
      <section name="EVENT" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
    </sectionGroup>
  </configSections>
  <ProppFrexx>
    <EVENT>
      <add key="OnApplicationStartup" value="" />
      <add key="OnApplicationShutdown" value="" />
      <add key="OnAir" value="" />
      <add key="OffAir" value="" />
      <add key="OnTalkoverON" value="" />
      <add key="OnTalkoverOFF" value="" />
      <add key="OnDetectSilence" value="" />
      <add key="OnDetectNoise" value="" />
      <add key="OnUserChanging" value="" />
      <add key="OnUserLogin" value="" />
      <add key="OnUserLogoff" value="" />
      <add key="OnSetMaster" value="" />
      <add key="OnSetSlave" value="" />
      <add key="OnMainFader" value="" />
      <add key="OnCalendarReloading" value="" />
      <add key="OnAutoLibraryReloading" value="" />
      <add key="OnAutoLibrarySaving" value="" />
      <add key="OnTalkuserON" value="" />
      <add key="OnTalkuserOFF" value="" />
      <add key="OnLineInFeedON" value="" />
      <add key="OnLineInFeedOFF" value="" />
      <add key="OnTimer" value="" />
      <add key="OnManualOperationON" value="" />
      <add key="OnManualOperationONSoft" value="" />
      <add key="OnManualOperationOFF" value="" />
      <add key="OnVoiceTrackingOpen" value="" />
      <add key="OnVoiceTrackingClose" value="" />
      <add key="OnOverlayStart" value="" />
      <add key="OnOverlayStop" value="" />
      <add key="TAOn" value="" />
      <add key="TAOff" value="" />
      <add key="OnPlaylistOpened" value="" />
      <add key="OnPlaylistClosed" value="" />
      <add key="OnPlaylistChanged" value="" />
      <add key="OnTrackLoad" value="" />
      <add key="OnTrackPlay" value="EXEC_WRITE_PLAYLIST_LOG ${yyyy}${MM}${dd}_${plsname}" />
      <add key="OnTrackPause" value="" />
      <add key="OnTrackStop" value="" />
      <add key="OnTrackCueOut" value="" />
      <add key="OnTrackEject" value="" />
      <add key="OnTrackReplace" value="" />
      <add key="OnTrackEmpty" value="" />
      <add key="OnTrackAdded" value="" />
      <add key="OnCurrentTrackChanged" value="" />
      <add key="OnTimecode" value="" />
      <add key="OnAutoPlayON" value="" />
      <add key="OnAutoPlayOFF" value="" />
      <add key="OnUseFadingON" value="" />
      <add key="OnUseFadingOFF" value="" />
      <add key="OnAutoLoadON" value="" />
      <add key="OnAutoLoadOFF" value="" />
      <add key="OnAutoUnloadON" value="" />
      <add key="OnAutoUnloadOFF" value="" />
      <add key="OnRemoveWhenPlayedON" value="" />
      <add key="OnRemoveWhenPlayedOFF" value="" />
      <add key="OnDJALoad" value="" />
      <add key="OnDJAPlay" value="" />
      <add key="OnDJAPause" value="" />
      <add key="OnDJAStop" value="" />
      <add key="OnDJAEject" value="" />
      <add key="OnDJBLoad" value="" />
      <add key="OnDJBPlay" value="" />
      <add key="OnDJBPause" value="" />
      <add key="OnDJBStop" value="" />
      <add key="OnDJBEject" value="" />
      <add key="OnDJCLoad" value="" />
      <add key="OnDJCPlay" value="" />
      <add key="OnDJCPause" value="" />
      <add key="OnDJCStop" value="" />
      <add key="OnDJCEject" value="" />
      <add key="OnDJDLoad" value="" />
      <add key="OnDJDPlay" value="" />
      <add key="OnDJDPause" value="" />
      <add key="OnDJDStop" value="" />
      <add key="OnDJDEject" value="" />
      <add key="OnScheduledPlaylistOpened" value="" />
      <add key="OnScheduledPlaylistClosed" value="" />
      <add key="OnTimeUpdateSync" value="" />
      <add key="OnPlaylistEnd" value="" />
      <add key="OnShowDocument" value="" />
      <add key="OnPlaylistBroken" value="" />
      <add key="OnUser1" value="" />
      <add key="OnUserName1" value="User 1" />
      <add key="OnUserIcon1" value="" />
      <add key="OnUser2" value="" />
      <add key="OnUserName2" value="User 2" />
      <add key="OnUserIcon2" value="" />
      <add key="OnUser3" value="" />
      <add key="OnUserName3" value="User 3" />
      <add key="OnUserIcon3" value="" />
      <add key="OnUser4" value="" />
      <add key="OnUserName4" value="User 4" />
      <add key="OnUserIcon4" value="" />
      <add key="OnUser5" value="" />
      <add key="OnUserName5" value="User 5" />
      <add key="OnUserIcon5" value="" />
      <add key="OnUser6" value="" />
      <add key="OnUserName6" value="User 6" />
      <add key="OnUserIcon6" value="" />
      <add key="OnUser7" value="" />
      <add key="OnUserName7" value="User 7" />
      <add key="OnUserIcon7" value="" />
      <add key="OnUser8" value="" />
      <add key="OnUserName8" value="User 8" />
      <add key="OnUserIcon8" value="" />
      <add key="OnUser9" value="" />
      <add key="OnUserName9" value="User 9" />
      <add key="OnUserIcon9" value="" />
      <add key="OnUser10" value="" />
      <add key="OnUserName10" value="User 10" />
      <add key="OnUserIcon10" value="" />
      <add key="OnUser11" value="" />
      <add key="OnUserName11" value="User 11" />
      <add key="OnUserIcon11" value="" />
      <add key="OnUser12" value="" />
      <add key="OnUserName12" value="User 12" />
      <add key="OnUserIcon12" value="" />
      <add key="OnUser13" value="" />
      <add key="OnUserName13" value="User 13" />
      <add key="OnUserIcon13" value="" />
      <add key="OnUser14" value="" />
      <add key="OnUserName14" value="User 14" />
      <add key="OnUserIcon14" value="" />
      <add key="OnUser15" value="" />
      <add key="OnUserName15" value="User 15" />
      <add key="OnUserIcon15" value="" />
      <add key="OnUser16" value="" />
      <add key="OnUserName16" value="User 16" />
      <add key="OnUserIcon16" value="" />
      <add key="OnUser17" value="" />
      <add key="OnUserName17" value="User 17" />
      <add key="OnUserIcon17" value="" />
      <add key="OnUser18" value="" />
      <add key="OnUserName18" value="User 18" />
      <add key="OnUserIcon18" value="" />
      <add key="OnUser19" value="" />
      <add key="OnUserName19" value="User 19" />
      <add key="OnUserIcon19" value="" />
      <add key="OnUser20" value="" />
      <add key="OnUserName20" value="User 20" />
      <add key="OnUserIcon20" value="" />
      <add key="OnUser21" value="" />
      <add key="OnUserName21" value="User 21" />
      <add key="OnUserIcon21" value="" />
      <add key="OnUser22" value="" />
      <add key="OnUserName22" value="User 22" />
      <add key="OnUserIcon22" value="" />
      <add key="OnUser23" value="" />
      <add key="OnUserName23" value="User 23" />
      <add key="OnUserIcon23" value="" />
      <add key="OnUser24" value="" />
      <add key="OnUserName24" value="User 24" />
      <add key="OnUserIcon24" value="" />
      <add key="OnUser25" value="" />
      <add key="OnUserName25" value="User 25" />
      <add key="OnUserIcon25" value="" />
      <add key="OnUser26" value="" />
      <add key="OnUserName26" value="User 26" />
      <add key="OnUserIcon26" value="" />
      <add key="OnUser27" value="" />
      <add key="OnUserName27" value="User 27" />
      <add key="OnUserIcon27" value="" />
      <add key="OnUser28" value="" />
      <add key="OnUserName28" value="User 28" />
      <add key="OnUserIcon28" value="" />
      <add key="OnUser29" value="" />
      <add key="OnUserName29" value="User 29" />
      <add key="OnUserIcon29" value="" />
      <add key="OnUser30" value="" />
      <add key="OnUserName30" value="User 30" />
      <add key="OnUserIcon30" value="" />
      <add key="OnUser31" value="" />
      <add key="OnUserName31" value="User 31" />
      <add key="OnUserIcon31" value="" />
      <add key="OnUser32" value="" />
      <add key="OnUserName32" value="User 32" />
      <add key="OnUserIcon32" value="" />
      <add key="OnUser33" value="" />
      <add key="OnUserName33" value="User 33" />
      <add key="OnUserIcon33" value="" />
      <add key="OnUser34" value="" />
      <add key="OnUserName34" value="User 34" />
      <add key="OnUserIcon34" value="" />
      <add key="OnUser35" value="" />
      <add key="OnUserName35" value="User 35" />
      <add key="OnUserIcon35" value="" />
      <add key="OnUser36" value="" />
      <add key="OnUserName36" value="User 36" />
      <add key="OnUserIcon36" value="" />
      <add key="OnUser37" value="" />
      <add key="OnUserName37" value="User 37" />
      <add key="OnUserIcon37" value="" />
      <add key="OnUser38" value="" />
      <add key="OnUserName38" value="User 38" />
      <add key="OnUserIcon38" value="" />
      <add key="OnUser39" value="" />
      <add key="OnUserName39" value="User 39" />
      <add key="OnUserIcon39" value="" />
      <add key="OnUser40" value="" />
      <add key="OnUserName40" value="User 40" />
      <add key="OnUserIcon40" value="" />
      <add key="OnUser41" value="" />
      <add key="OnUserName41" value="User 41" />
      <add key="OnUserIcon41" value="" />
      <add key="OnUser42" value="" />
      <add key="OnUserName42" value="User 42" />
      <add key="OnUserIcon42" value="" />
      <add key="OnUser43" value="" />
      <add key="OnUserName43" value="User 43" />
      <add key="OnUserIcon43" value="" />
      <add key="OnUser44" value="" />
      <add key="OnUserName44" value="User 44" />
      <add key="OnUserIcon44" value="" />
      <add key="OnUser45" value="" />
      <add key="OnUserName45" value="User 45" />
      <add key="OnUserIcon45" value="" />
      <add key="OnUser46" value="" />
      <add key="OnUserName46" value="User 46" />
      <add key="OnUserIcon46" value="" />
      <add key="OnUser47" value="" />
      <add key="OnUserName47" value="User 47" />
      <add key="OnUserIcon47" value="" />
      <add key="OnUser48" value="" />
      <add key="OnUserName48" value="User 48" />
      <add key="OnUserIcon48" value="" />
      <add key="OnUser49" value="" />
      <add key="OnUserName49" value="User 49" />
      <add key="OnUserIcon49" value="" />
      <add key="OnUser50" value="" />
      <add key="OnUserName50" value="User 50" />
      <add key="OnUserIcon50" value="" />
      <add key="OnCartwall1Play" value="EXEC_SEND_DRAIRENCE_SETLEDBLINK *[TOINT:{${cartid}}:{vert}:{8}:{2}]|1|0|1" />
      <add key="OnCartwall1Pause" value="EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert}:{8}:{2}]|2" />
      <add key="OnCartwall1Selected" value="" />
      <add key="OnCartwall1Looped" value="" />
      <add key="OnCartwall1Changed" value="ASYNC &#xD;&#xA;SLEEP 300&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 1|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 3|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 5|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 7|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 9|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 11|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 13|0&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 1|2&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 3|2&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 5|2&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 7|2&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 9|2&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 11|2&#xD;&#xA;EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 13|2" />
      <add key="OnCartwall2Play" value="EXEC_SEND_DRAIRENCE_SETLEDBLINK *[TOINT:{${cartid}}:{vert2}:{8}:{2}]|1|0|1" />
      <add key="OnCartwall2Pause" value="EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert2}:{8}:{2}]|2" />
      <add key="OnCartwall2Selected" value="" />
      <add key="OnCartwall2Looped" value="" />
      <add key="OnCartwall2Changed" value="ASYNC &#xD;&#xA;SLEEP 300&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 2|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 4|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 6|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 8|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 10|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 12|0&#xD;&#xA;EXEC_SEND_DRAIRENCE_SETLED 14|0&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 2|2&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 4|2&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 6|2&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 8|2&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 10|2&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 12|2&#xD;&#xA;EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 14|2" />
      <add key="OnCartwall1AnyCartStarted" value="" />
      <add key="OnCartwall1AnyCartEnded" value="" />
      <add key="OnCartwall2AnyCartStarted" value="" />
      <add key="OnCartwall2AnyCartEnded" value="" />
      <add key="OnOutputON" value="" />
      <add key="OnOutputOFF" value="" />
      <add key="OnOutputMute" value="" />
      <add key="OnOutputUnmute" value="" />
      <add key="OnOutputSNDOn" value="" />
      <add key="OnOutputSNDOff" value="" />
      <add key="OnOutputRECOn" value="" />
      <add key="OnOutputRECOff" value="" />
      <add key="OnOutputFaderStart" value="" />
      <add key="OnOutputFaderStop" value="" />
      <add key="OnOutputFader" value="" />
      <add key="OnOutputGain" value="" />
      <add key="OnOutputPan" value="" />
      <add key="OnInputON" value="" />
      <add key="OnInputOFF" value="" />
      <add key="OnInputMute" value="" />
      <add key="OnInputUnmute" value="" />
      <add key="OnInputSNDOn" value="" />
      <add key="OnInputSNDOff" value="" />
      <add key="OnInputRECOn" value="" />
      <add key="OnInputRECOff" value="" />
      <add key="OnInputFaderStart" value="" />
      <add key="OnInputFaderStop" value="" />
      <add key="OnInputFader" value="" />
      <add key="OnInputGain" value="" />
      <add key="OnInputPan" value="" />
      <add key="OnPFLShow" value="" />
      <add key="OnPFLPlay" value="" />
      <add key="OnPFLHide" value="" />
      <add key="OnPFLOn" value="" />
      <add key="OnPFLOff" value="" />
      <add key="OnSchedulerStart" value="" />
      <add key="OnSchedulerStop" value="" />
      <add key="OnScriptStarting" value="" />
      <add key="OnScriptStarted" value="" />
      <add key="OnScriptStopping" value="" />
      <add key="OnScriptStopped" value="" />
      <add key="OnScriptExecute" value="" />
      <add key="OnScriptLooped" value="" />
      <add key="OnOverlayShown" value="" />
      <add key="OnOverlayDelayed" value="" />
      <add key="OnOverlayPlayed" value="" />
      <add key="OnOverlayTrackPlay" value="" />
      <add key="OnOverlayStopped" value="" />
      <add key="OnOverlayClosed" value="" />
      <add key="OnProgramImported" value="" />
      <add key="OnOverlayImported" value="" />
      <add key="OnMissingProgramImport" value="" />
      <add key="OnMissingOverlayImport" value="" />
      <add key="OnStreamingStarted" value="" />
      <add key="OnStreamingStopped" value="" />
      <add key="OnStreamingDisconnected" value="" />
      <add key="OnStreamingSongTitleChanged" value="" />
      <add key="OnMODStreamShown" value="" />
      <add key="OnMODStreamConnected" value="" />
      <add key="OnMODStreamNotConnected" value="" />
      <add key="OnMODStreamWaiting" value="" />
      <add key="OnMODStreamPlaying" value="" />
      <add key="OnMODStreamPaused" value="" />
      <add key="OnMODStreamStopped" value="" />
      <add key="OnMODStreamClosed" value="" />
      <add key="OnSTANDBYLoad" value="" />
      <add key="OnSTANDBYPlay" value="" />
      <add key="OnSTANDBYPause" value="" />
      <add key="OnSTANDBYStop" value="" />
      <add key="OnSTANDBYEject" value="" />
      <add key="OnGlobalLogChanged" value="" />
      <add key="OnPlaylistLogChanged" value="" />
      <add key="OnTCPServerStarted" value="" />
      <add key="OnTCPServerStopped" value="" />
      <add key="OnMIDI1ServerStarted" value="" />
      <add key="OnMIDI1ServerStopped" value="" />
      <add key="OnMIDI2ServerStarted" value="" />
      <add key="OnMIDI2ServerStopped" value="" />
      <add key="OnSerialServerStarted" value="" />
      <add key="OnSerialServerStopped" value="" />
      <add key="OnOSCServerStarted" value="" />
      <add key="OnOSCServerStopped" value="" />
      <add key="OnIOWarriorStarted" value="" />
      <add key="OnIOWarriorStopped" value="" />
      <add key="OnVellemanStarted" value="" />
      <add key="OnVellemanStopped" value="" />
      <add key="OnDRAirenceStarted" value="" />
      <add key="OnDRAirenceStopped" value="" />
      <add key="OnDRAirliteStarted" value="" />
      <add key="OnDRAirliteStopped" value="" />
      <add key="OnEmberStarted" value="" />
      <add key="OnEmberStopped" value="" />
      <add key="OnLivewireStarted" value="" />
      <add key="OnLivewireStopped" value="" />
      <add key="OnGPIOServiceStarted" value="" />
      <add key="OnGPIOServiceStopped" value="" />
      <add key="OnWheatstoneStarted" value="" />
      <add key="OnWheatstoneStopped" value="" />
      <add key="OnAdvantechStarted" value="" />
      <add key="OnAdvantechStopped" value="" />
      <add key="OnAxelTechStarted" value="" />
      <add key="OnAxelTechStopped" value="" />
    </EVENT>
  </ProppFrexx>
</configuration>
These are my settings of the GPIO-Client.
<configuration>
  <configSections>
      <section name="DRAIRENCEMAP" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
    </sectionGroup>
  </configSections>
  <ProppFrexx>
    <DRAIRENCEMAP>
      <add key="0" value="26|0|PROGRAM_SCHEDULER_OFF" />
      <add key="1" value="26|1|PROGRAM_SCHEDULER_ON" />
      <add key="2" value="27|0|PLS_CURRENT_EJECTNOFADE_A" />
      <add key="3" value="27|1|PLS_CURRENT_PLAY_A" />
      <add key="4" value="30|0|PLS_CURRENT_EJECTNOFADE_B" />
      <add key="5" value="30|1|PLS_CURRENT_PLAY_B" />
      <add key="6" value="33|0|PLS_CURRENT_EJECTNOFADE_C" />
      <add key="7" value="33|1|PLS_CURRENT_PLAY_C" />
      <add key="8" value="1|1|CW1_PLAY_CART_1" />
      <add key="9" value="2|1|CW2_PLAY_CART_1" />
      <add key="10" value="3|1|CW1_PLAY_CART_2" />
      <add key="11" value="4|1|CW2_PLAY_CART_2" />
      <add key="12" value="5|1|CW1_PLAY_CART_3" />
      <add key="13" value="6|1|CW2_PLAY_CART_3" />
      <add key="14" value="7|1|CW1_PLAY_CART_4" />
      <add key="15" value="8|1|CW2_PLAY_CART_4" />
      <add key="16" value="9|1|CW1_PLAY_CART_5" />
      <add key="17" value="10|1|CW2_PLAY_CART_5" />
      <add key="18" value="11|1|CW1_PLAY_CART_6" />
      <add key="19" value="12|1|CW2_PLAY_CART_6" />
      <add key="20" value="13|1|CW1_PLAY_CART_7" />
      <add key="21" value="14|1|CW2_PLAY_CART_7" />
      <add key="22" value="15|1|CW1_FADEOUT_ALL" />
      <add key="23" value="16|1|CW2_FADEOUT_ALL" />
    </DRAIRENCEMAP>
  </ProppFrexx>
</configuration>
To be continued...
Knarrenheinz
...Continued
And this is the mixer file. The mixer isn't fully setup yet.
<configuration>
  <configSections>
      <section name="ROUTE" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="MixerOutputs" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="MixerInputs" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="MixerPresets" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.Main" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.0" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.1" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.2" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.3" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.4" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.5" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.6" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.7" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.8" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.9" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.10" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
      <section name="_CURRENT.11" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
    </sectionGroup>
  </configSections>
  <ProppFrexx>
    <ROUTE>
      <add key="PlayerA" value="P1" />
      <add key="PlayerB" value="P2" />
      <add key="PlayerC" value="P3" />
      <add key="PlayerD" value="CART" />
      <add key="StandbyPlayer" value="PLAY" />
      <add key="OverlayPlayer" value="PLAY" />
      <add key="PFL" value="PFL" />
      <add key="QuickMonitor" value="PFL" />
      <add key="CartWall1" value="CART" />
      <add key="CartWall2" value="CART" />
      <add key="Input" value="OUT" />
      <add key="Streaming" value="OUT" />
      <add key="MODStreamPlayer" value="PLAY" />
    </ROUTE>
    <MixerOutputs>
      <add key="Output1" value="PLAY|3|44100|True|False|True|False|True|0|0|OUT|False||False|False|0|0|False|True|True|NoSound|-1|False|-1|0|False|False|1" />
      <add key="Output2" value="OUT|2|48000|False|False|True|False|True|10|0||False||False|False|0|0|False|True|True|{0.0.0.00000000}.{23389f22-a312-4a92-a4ef-2e50ba432095}D&amp;R Airence MK2 Channel 07 (DJ Player A) (9- USB AUDIO  CODEC)|-1|False|-1|0|False|False|1" />
      <add key="Output3" value="PFL|2|44100|False|False|True|False|True|2|0||False||False|False|0|0|False|True|True|{0.0.0.00000000}.{0b9d1f2d-8073-4d74-8180-3be21d860c24}ERROR N/A: LG ULTRAFINE (HD Audio Driver for Display Audio)|-1|False|-1|0|False|False|1" />
      <add key="Output4" value="Out 4|0|44100|True|False|True|False|True|1|0||False||False|False|0|0|False|True|True|Default|-1|False|-1|0|False|False|1" />
      <add key="Output5" value="P1|0|48000|True|False|True|False|True|2|1||False||False|False|0|0|False|True|True|{0.0.0.00000000}.{23389f22-a312-4a92-a4ef-2e50ba432095}D&amp;R Airence MK2 Channel 07 (DJ Player A) (9- USB AUDIO  CODEC)|-1|False|-1|0|False|False|1" />
      <add key="Output6" value="P2|0|48000|True|False|True|False|True|3|1||False||False|False|0|0|False|True|True|{0.0.0.00000000}.{2868a2dc-8173-4c3a-8226-0e7c4e7a85ee}D&amp;R Airence MK2 Channel 08 (DJ Player B) (10- USB AUDIO  CODEC)|-1|False|-1|0|False|False|1" />
      <add key="Output7" value="P3|0|48000|True|False|True|False|True|5|1||False||False|False|0|0|False|True|True|{0.0.0.00000000}.{acd71f0c-280d-4429-b98e-4701af9689e0}D&amp;R Airence MK2 Channel 09 (DJ Player C) (11- USB AUDIO  CODEC)|-1|False|-1|0|False|False|1" />
      <add key="Output8" value="CART|0|48000|True|False|True|False|True|6|1||False||False|False|0|0|False|True|True|{0.0.0.00000000}.{c7e00fe6-e163-4a21-9e8f-cdbcd74690f6}D&amp;R Airence MK2 Channel 10 (Cartwall) (12- USB AUDIO  CODEC)|-1|False|-1|0|False|False|1" />
    </MixerOutputs>
    <MixerInputs>
      <add key="Input1" value="MIC1|2|44100|True|False|True|45|0|OUT|False||False|False|False|0|0|True|False|True|{0.0.0.00000000}.{c7e00fe6-e163-4a21-9e8f-cdbcd74690f6}D&amp;R Airence MK2 Channel 10 (Cartwall) (12- USB AUDIO  CODEC)|-1|False|-1|0|False|False" />
      <add key="Input2" value="In 2|0|44100|True|False|True|0|0|OUT|False||False|False|False|0|0|True|False|True|Default|-1|False|-1|0|False|False" />
      <add key="Input3" value="In 3|0|44100|True|False|True|0|0|OUT|False||False|False|False|0|0|True|False|True|Default|-1|False|-1|0|False|False" />
      <add key="Input4" value="In 4|0|44100|True|False|True|0|0|OUT|False||False|False|False|0|0|True|False|True|Default|-1|False|-1|0|False|False" />
    </MixerInputs>
    <MixerPresets>
      <add key="ActivePreset" value="_CURRENT" />
      <add key="_CURRENT" value="0" />
    </MixerPresets>
    <_CURRENT.Main>
      <add key="MasterVolume" value="1" />
    </_CURRENT.Main>
    <_CURRENT.0>
      <add key="MixerChannel" value="Output.PLAY" />
      <add key="ON" value="True" />
      <add key="Mute" value="False" />
      <add key="ShowOnAirTime" value="False" />
      <add key="Volume" value="1" />
      <add key="AdjustExternalVolume" value="False" />
      <add key="ExternalVolume" value="1" />
      <add key="SND2MixerCount" value="1" />
      <add key="SND2Mixer0" value="PFL" />
      <add key="SND2Auto" value="0" />
      <add key="SND2" value="False" />
      <add key="SND2PostVolume" value="True" />
      <add key="SND2Volume" value="1" />
      <add key="SND2Pan" value="0" />
      <add key="RECOutputFolder" value="" />
      <add key="RECAutoSensing" value="0" />
      <add key="EVENT_OnFaderStart" value="" />
      <add key="EVENT_OnFaderStop" value="" />
      <add key="EVENT_OnFader" value="" />
      <add key="EVENT_OnVolumeChanged" value="" />
      <add key="EVENT_OnPan" value="" />
      <add key="EVENT_OnPanChanged" value="" />
      <add key="EVENT_OnGain" value="" />
      <add key="EVENT_OnGainChanged" value="" />
      <add key="EVENT_OnMute" value="" />
      <add key="EVENT_OnUnmute" value="" />
      <add key="EVENT_OnOn" value="" />
      <add key="EVENT_OnOff" value="" />
      <add key="EVENT_OnRecOn" value="" />
      <add key="EVENT_OnRecOff" value="" />
      <add key="EVENT_OnAutoRecOn" value="" />
      <add key="EVENT_OnAutoRecOff" value="" />
      <add key="EVENT_OnSnd2On" value="" />
      <add key="EVENT_OnSnd2Off" value="" />
      <add key="EVENT_OnSnd2Fader" value="" />
      <add key="EVENT_OnSnd2VolumeChanged" value="" />
      <add key="EVENT_OnSnd2Pan" value="" />
      <add key="EVENT_OnSnd2PanChanged" value="" />
      <add key="EVENT_OnSilence" value="" />
      <add key="EVENT_OnNoise" value="" />
      <add key="EVENT_OnTimer" value="" />
      <add key="TimerEventInterval" value="0" />
      <add key="Gain" value="0" />
      <add key="Pan" value="0" />
      <add key="Mono" value="-1" />
      <add key="DAMP.ON" value="False" />
      <add key="DAMP.Preset" value="-1" />
      <add key="DAMP.Delay" value="0" />
      <add key="DAMP.Gain" value="0" />
      <add key="DAMP.Quiet" value="0" />
      <add key="DAMP.Rate" value="0" />
      <add key="DAMP.Target" value="1" />
      <add key="EQ.ON" value="False" />
      <add key="EQ0.Gain" value="0" />
      <add key="EQ1.Gain" value="0" />
      <add key="EQ2.Gain" value="0" />
      <add key="EQ3.Gain" value="0" />
      <add key="EQ4.Gain" value="0" />
      <add key="EQ5.Gain" value="0" />
      <add key="EQ6.Gain" value="0" />
      <add key="EQ7.Gain" value="0" />
      <add key="EQ8.Gain" value="0" />
      <add key="EQ9.Gain" value="0" />
      <add key="EQ10.Gain" value="0" />
      <add key="COMP.ON" value="False" />
      <add key="COMP.Preset" value="-1" />
      <add key="COMP.Attack" value="20" />
      <add key="COMP.Gain" value="5" />
      <add key="COMP.Ratio" value="3" />
      <add key="COMP.Release" value="200" />
      <add key="COMP.Threshold" value="-15" />
      <add key="DSP1.File" value="" />
      <add key="DSP1.Bypass" value="False" />
      <add key="DSP1.ShowEditor" value="False" />
      <add key="DSP1.Program" value="-1" />
      <add key="DSP1.ParamCount" value="0" />
      <add key="DSP1.Params" value="" />
      <add key="DSP1.ProgramCount" value="0" />
      <add key="DSP2.File" value="" />
      <add key="DSP2.Bypass" value="False" />
      <add key="DSP2.ShowEditor" value="False" />
      <add key="DSP2.Program" value="-1" />
      <add key="DSP2.ParamCount" value="0" />
      <add key="DSP2.Params" value="" />
      <add key="DSP2.ProgramCount" value="0" />
      <add key="DSP3.File" value="" />
      <add key="DSP3.Bypass" value="False" />
      <add key="DSP3.ShowEditor" value="False" />
      <add key="DSP3.Program" value="-1" />
      <add key="DSP3.ParamCount" value="0" />
      <add key="DSP3.Params" value="" />
      <add key="DSP3.ProgramCount" value="0" />
      <add key="DSP4.File" value="" />
      <add key="DSP4.Bypass" value="False" />
      <add key="DSP4.ShowEditor" value="False" />
      <add key="DSP4.Program" value="-1" />
      <add key="DSP4.ParamCount" value="0" />
      <add key="DSP4.Params" value="" />
      <add key="DSP4.ProgramCount" value="0" />
      <add key="PLMShowMode" value="1" />
    </_CURRENT.0>
    <_CURRENT.1>
      <add key="MixerChannel" value="Output.OUT" />
      <add key="SND2Auto" value="3" />
    </_CURRENT.1>
    <_CURRENT.2>
      <add key="MixerChannel" value="Output.PFL" />
      <add key="SND2MixerCount" value="0" />
    </_CURRENT.2>
    <_CURRENT.3>
      <add key="MixerChannel" value="Output.Out 4" />
      <add key="DAMP.Preset" value="0" />
      <add key="DAMP.Delay" value="0.5" />
      <add key="DAMP.Gain" value="1" />
      <add key="DAMP.Quiet" value="0.02" />
      <add key="DAMP.Rate" value="0.01" />
      <add key="DAMP.Target" value="0.92" />
      <add key="COMP.Preset" value="0" />
      <add key="COMP.Attack" value="24" />
      <add key="COMP.Gain" value="3.7" />
      <add key="COMP.Ratio" value="2" />
      <add key="COMP.Release" value="800" />
    </_CURRENT.3>
    <_CURRENT.4>
      <add key="MixerChannel" value="Output.P1" />
    </_CURRENT.4>
    <_CURRENT.5>
      <add key="MixerChannel" value="Output.P2" />
    </_CURRENT.5>
    <_CURRENT.6>
      <add key="MixerChannel" value="Output.P3" />
    </_CURRENT.6>
    <_CURRENT.7>
      <add key="MixerChannel" value="Output.CART" />
      <add key="DAMP.ON" value="True" />
      <add key="EQ.ON" value="True" />
      <add key="EQ0.Gain" value="-3" />
      <add key="EQ1.Gain" value="-1" />
      <add key="EQ2.Gain" value="1" />
      <add key="EQ3.Gain" value="2" />
      <add key="EQ4.Gain" value="3" />
      <add key="EQ5.Gain" value="-1" />
      <add key="EQ6.Gain" value="-1" />
      <add key="EQ9.Gain" value="4" />
      <add key="EQ10.Gain" value="4" />
      <add key="COMP.ON" value="True" />
    </_CURRENT.7>
    <_CURRENT.8>
      <add key="MixerChannel" value="Input.MIC1" />
      <add key="Mute" value="True" />
    </_CURRENT.8>
    <_CURRENT.9>
      <add key="MixerChannel" value="Input.In 2" />
    </_CURRENT.11>
  </ProppFrexx>
</configuration>
Maybe you see something more then I do. Even with my third and fourth eye on (glasses) I don’t see it anymore! :mrgreen:
:!: PS: I took out some code at the end because there were too much characters in this post! :!:
Only an ‚space‘ at the end of the ASYNC command.
I will send you a video tomorrow…
