ACM / PCM encoder
fred48fm
Re: ACM / PCM encoder
Post by fred48fm »
That solution is unfortunately not compatible with our infrastructure.
AoIP require direct network connection but that is not possible here. Our different sites don't allow publicly open network ports and vpn is also not an option. :-)
? But how should then a PCM stream to an ICEcast server work? That requires the same as an AoIP solution.
But of course I don’t your infrastructure limitations…
