Multi Track Segue Editor no longer saves.
Re: Multi Track Segue Editor no longer saves.
Yes, I can also perfectly adjust those rows... no problem!
atlantic
Post by atlantic »
Sorry, it doesn't work at the studio or in my studio. I can edit it but it is not saved.
https://www.dropbox.com/scl/fi/j21rue5t ... s7xz7&dl=0
I fully believe that you have those issues!
But I have now tested it on 3 different PCs and can not reproduce the issue. As such, I can not fix something that is not happening here.
It also seems strange, that it seems to not happen on your side with regular playlists as well as probably not all playlist entries?!
If yes, maybe the issue is related to certain file types on your side? I am sorry, but I can also only shoot into the dark…
atlantic
Post by atlantic »
Bernd, indeed it is strange. I'll look into it further here.
I just had a cusomer who found a bug in the latest audio lib I am using (actually bass_fx.dll).
Not sure, if that is related to your issue, as I couldn't reproduce it, but maybe it is...
I changed that and re-uploaded the v4.4.4.1 with the correct dll.
You might try the latest version again. You can download the zip from here:
https://www.proppfrexx.radio42.com/down ... te4433.zip
Just unzip it all into the installation folder.
atlantic
Post by atlantic »
radio42 wrote: 03 Mar 2024 17:33 I'll also do some more testing... maybe you can spot any specific combo... we will find the issue somehow.
Here is the last (previous) v4.4.3.3. - maybe you can test that again to see, if it heals the issue:
https://www.proppfrexx.radio42.com/Prop ... te4433.zip
Just unzip it all in the installation folder...
link doesn't work
atlantic
Post by atlantic »
I also did some tests here. With Windows 11 and 10. On a laptop with Windows 11 and a desktop with Windows 10, everything works as it should.
It doesn't work on two other PCs with Windows 10. When loading in the player, the time of the music bed changes.
With version 4.4.3.3 we did not have this problem.
It can't be the Pre Generation playlist, these are made 7 days in advance.
Link corrected.
Note, that you might also try the latest full setup again, maybe something got broken and I also changed on dll.
atlantic
Post by atlantic »
I installed the updates and the older version. But it's the same. This afternoon I monitored everything in the studio. Some DJs have okay hours and others don't. Could it depend on which version of Windows they are using? Sorry for thinking out loud. I know that the hour I sent you was recorded with Windows 11. I will also listen to the audio files of those hours where things went wrong a few weeks ago. I'll keep you informed.
I don't think it should be Win11/10 related.
