Any quick way to delete old advertisement campaigns?
Re: Any quick way to delete old advertisement campaigns?
You now test a function which was added 9 months ago?
I will also test this again. But I guess there must be a mismatch with the ‚end date‘?
rr002
Post by rr002 »
Yes, it was easy to postpone doing the maintenance and cleaning when I knew can be done with only one click and yes should have tested sooner. But yes something can be wrong with the EndDate there for sure.
Right now seems like this has also happened:
Campaign EndDate is let's say 29. February 2024 or 29. March 2024 or 29. April 2024 - all EndDates like this within 3 months forward from today the campaigns also seem to be be deleted with this command somehow.
You are right, I will correct the feature in the next release!
rr002
Post by rr002 »
Thank You so much for fast reply and action!
rr002
Post by rr002 »
Thank You for the fix, I tested now and it works perfectly and saved a lot of time! Awesome feature!
