Problem Log Importer
This forum is unmoderated!
Re: Problem Log Importer
Your log file format has changed ! As such it is of course not matching anymore! So you need to correct that and make sure, that your Powergold export log format matches the ProppFrexx import format definition - else it will not work.
Compare yourself:
Line 1: your old format (20220626.asc)
Line 2: your new format (20220704.asc)
Slicker Than Your Average (Original Mix)         Discotron                                              b9860ef3-e0df-433d-8423-deaf212e      05:41       122062600:00:15MUS E:\SONIDO 104 MUSIC\LA CHERCHA 2\Discotron - Slicker Than Your Average (Original Mix).aiff
CANDY                                           ROSALIA                                                99ab88f0992e48f0a492939c6bddd1a7      03:30       222070400:42:46MUS+E:\SONIDO 104 MUSIC\2022 MUSIC\Rosalía - CANDY.flac
As you can see, the title field is 1 byte shorter (length=48) and as such shifts the position of the remaining fields by -1 as well!
So you need to adjust the ProppFrexx definition or change your Powergold export definition to what it was before?!
However, those changes could easily be checked by yourself.
Any News?
