Start Up Problems.
Nootje2+0
Re: Start Up Problems.
Post by Nootje2+0 »
Nootje2+0
Post by Nootje2+0 »
I have coverted everthing to mp3, but still he grab the WAV format?
That looks like the files you referenced are corrupt!
Maybe you used Apple reference files instead of real physical files?
So please send one of those file to me, eg. via eMail.
I still don’t know where those files are coming from ?
Did you dragged them into an empty playlist?
Did you open an existing playlist?
If yes, please show that playlist!
Did you scheduled them via a script?
If yes, how does the script and your related media libs look like.
Just converting external files from .wav to .mp3 wouldn’t help, as you would need to create new media libs, eg. if you used playlist based media libs.
If you are using folder based media libs, you wold need to ReScan those folders!
Nootje2+0
Post by Nootje2+0 »
I haven end you a e-mail.
First i open "the Tagger program" then open with the folder (on the top left) and then find the muziek folder on the computer. i can play the songs on the Proppfrexx players?
Nootje2+0
Post by Nootje2+0 »
Nootje2+0
Post by Nootje2+0 »
Nootje2+0 wrote: 06 May 2020 20:36 I haven end you a e-mail.
Sorry, but have send me an .mp3 file - and that plays just fine! Like you new screenshots also prove!
So no wonder I assume.
You said, that ProppFrexx has a problem with your .wav files - which you also posted in your first screenshot!
As such I expected a .wav file!
So please send one of these errored .wav files over - which you also tested in the screenshot!
However, you also don't need to open the 'Tagger' application in order to look at folder or to drag files over to ProppFrexx.
a) you can use the Find window to quickly search thru tracks in your media libs
b) you can use the Explorer window to quickly scan your folders/drives
c) or you can even use the normal Windows Explorer to drag files over.
Also note, that on a) and b) you can use the Quick Monitor to pre-listen to tracks quickly - just press the Space-Bar to play or stop the selected track and use the keyboard arrow keys left/right to scan thru the files.
Maybe you should look at these Tutorial Videos:
viewtopic.php?f=5&t=1018
