v4.1.5.15 - stable
Re: v4.1.5.15 - stable
Thanks for sending me a screenshot and movie:
The main picture shows, that the GPIO Client is NOT connected to ProppFrexx ONAIR!
Please try to clear the field 'Server Address' and press Enter, to let it find the new address automatically or type in the IP address manually.
In addition make sure, that the GPIO client AND ProppFrexx ONAIR use exactly the same (new) version (incl. all DLLs)!!!
On the video it looks like 2 PCs, but if it is just one, as you wrote above, that is okay (assuming, that the GPIO client is using the exact same installation folder and assume, that the GPIO client was also closed during the update).
Else make sure, that both PF and the GPIO client shows v4.1.5.15!
jbmusic
Post by jbmusic »
Hi Bernd
Sorry but I send you the wrong picture because I tried to disable & enable again ... but the connection was green without succes. After disable the firewall it dit not helpt me out to solve this issue.
Finally I did a tcp release and renew and that worked well. It seems to be they there was a resolving not going properly
Glad to hear, that all is solved now!
