Moving a track insert sometimes results in duplicate insert
Re: Moving a track insert sometimes results in duplicate insert
I am sorry, I can not reproduce that here.
When I drag a Track-Insert marker around - the original position does not remain visible.
Can you post a short video to take a look at...
franksiegers
Post by franksiegers »
Sorry, it took a while but here is the video. I've made this with PFOA 4.2.0.4: https://imgur.com/a/MGFBJ9H
The issue is partly resolved: the sound is not playing twice so that's good, but the marker is shown twice.
I also had another question about this. Please let me know if I need to create a new topic for this:
I use lots of inserts that are inserted at the CueIn point of the next track. Often I'd like to manually move them around a bit for the best result. Unfortunately when I try and drag the blue TI-marker, PFOA always moves the In and Full markers first. So I have to move 3 markers (In, Full, TI) and then move In and Full back to their original position. Could this be changed to that PF would select the TI when there are several markers at the same position?
Greetings,
Frank
Unfortunately I cannot reproduce this issue - as you can see in this video it doesn't happen in all my tests:
https://imgur.com/a/YqsV1ve
To further investigate, please send me your related audio file your are testing with.
If you haven't saved the meta data (cue-points, track inserts etc.) to the audio files TAGs, but to a .pfmd file or into a playlist - please send this as well.
franksiegers
What is the best way to send these to you?
WeTransfer, via eMail - whatever...
