Cardwall / D&R Airlite
Re: Cardwall / D&R Airlite
It’s delayed, I’ll post it today in the evening...
franksiegers
Post by franksiegers »
Awesome, thanks!
A new v4.1.5.14-Beta is available which adds the new *[TOINT] macro function parameters.
Use the "Check for Beta-Version..." menu under the blue question mark icon at the very top right to update.
In you case you can try:
EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert}:{2}:{8}]|${cartisselected}
or
EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{horz}:{8}:{2}]|${cartisselected}
TOINT (converts a numeric value to an integer):
Returns a new string by converting a num value.
Syntax:
*[TOINT:{num}:{conv}:{p1}:{p2}]
Parameters:
{num} the original numeric value to format
{conv} the conversion function name to apply to the num
‘round’ : rounds num to the nearest integral value
p1: not used
p2: not used (can be omitted)
‘add’ : adds a value to num
p1: the value to add (e.g. 5)
‘multi’ : multiplies a value to num
p1: the value to multiply (e.g. 2.0)
‘div’ : devides num by a value
p1: the divisor (e.g. 2.0)
‘mod’ : reminder after division; num = num % p1
‘odd’ : makes the num value odd; num = (num * p1) - 1
p1: the value to multiply (e.g. 2)
‘even’ : makes the num value even; num = (num / p1) + 1
p1: the value to divide (e.g. 2)
‘vert’ : arranges the num value vertical (in p2 columns)
p1: the number of vertical rows (e.g. 8)
p2: not used (if omitted, defaults to 2)
‘horz’ : arranges the num value horizontal (in p2 columns)
‘none’ : uses num unmodified
p1: not used
{p1} see the above notes for the conv parameter
{p2} optional, can be omitted, see the above notes for the conv parameter
Example 1:
*[TOINT:{${cartid}}:{add}:{7.0}]
Will result to:
8 assuming the macro ${cartid} will resolve to 1.
Example 2:
*[TOINT:{${cartid}}:{vert}:{8}:{2}]
Will result to:
9 assuming the macro ${cartid} will resolve to 2.
Example 3:
Will result to:
2 assuming the macro ${cartid} will resolve to 9.
Michel67
Post by Michel67 »
"Check for Beta-Version failed! Could not connect te the radio42 server"
this is since a the last update
Can you please retry - maybe a temp. server issue somewhere.
I just tried it and it seems to be working fine now again.
franksiegers
It's working here as well. I've downloaded the beta and changed the OnCartSelected.
Everything is working well now. Thank alot Bernd, great service!
Will this be added to the default release as well (can I install normal versions or should I stay on beta only?).
Cheers,
Frank
Michel67
Post by Michel67 »
works again
Yes, this be part of the next regular version, so you can safely use the BETA.
franksiegers
Would this be possible with 2 cartwalls as well? PFOA could play from the cartwall that was last selected?
What should be possible?
Both cartwalls exist side by side in parallel, so there is no single selected cartwall.
