cpl next track excluding jingle
moogwill
Re: cpl next track excluding jingle
Post by moogwill »
Export this .txt list when the hook container is loaded in the player, and trigger when the hook container is played.... would be the easiest way I suppose.
Trigger and export would be the same.
As said I am not sure to be able to provide something like this, but I’ll double check.
moogwill
Post by moogwill »
thanks
moogwill
Post by moogwill »
if the same action start trigger & export... could it be a problem??? I mean if the trigger start an action tu use a .txt file that is writing right at the same time???.
No - if, then I will implement a macro which resolves to a string of multiple entries - i.e. you are controlling the writing to the file anyhow - just like you do today...
A new v4.1.5.0 is out - it adds a new streaming option to use the current song update filter to determine the next track. The existing macros can than be used as is.
moogwill
Post by moogwill »
Thanks for that.... Perfect... here's the result
https://youtu.be/M4iSCiJnRiA
