Pf does not start anymore
Re: Pf does not start anymore
Any News?
Bumperke
Post by Bumperke »
Still working on it😒
So what happened after you renamed/moved away the config folder?
Bumperke
Post by Bumperke »
radio42 wrote: 15 Sep 2019 22:23 So what happened after you renamed/moved away the config folder?
Nothing, it looks bigger than expected
What do you mean by bigger? Do you have any idea what it is causing?
As I haven’t heard from anyone else having that issue...
Bumperke
Post by Bumperke »
radio42 wrote: 16 Sep 2019 20:16 What do you mean by bigger? Do you have any idea what it is causing?
Some stupid idiot has destroyed everything. Whenever I do have the time I will install PF again. Last thing I will try to install the last update. I have to re-install anyway. :oops:
Thanks for the update - I mark this topic as closed, as it sounds like it was not really a ProppFrexx issue.
