Open Sound Control (OSC) with your iPhone/iPad
j0han
Re: Open Sound Control (OSC) with your iPhone/iPad
Post by j0han »
hmm, cant see any tracks in Cardwalls on the iPad now.
And same goes with MAIN.
Cant see any tracks, but if ill press ex. talk over, it respond to that
Feels like, you can controll the PF but you cant get any visuals from it.
Anyone having the same issue?
In Remoting.
Input <my pc ip>:9000
delay 0
osc enable
outout:9001
mapping orppfrexx onair iPad
Transport UDp Unicast
j0han
Post by j0han »
Everything checked.
Open'd port 9000-9001 on router for 192.168.1.3 which is my PC.
RCM/OSC is running, Green Icon, says Input Started/Output Offline
I can change ex, talk over volume, but its like no information is beeing sent to the iPad instance.
All working now,
Output: :port (example :9001 - without any ip-address!)
I setup with iPad IP 192.168.1.8:9001
And now it works :)
Thanks!
Ah yes, if you are running it via a router, then it also needs an ip-address:port in the "Output:" setting to allow the router to recognize the port-forwarding ;-)
Sound like a network or connection issue for the 'Incomming' port.
First check your general settings within ProppFrexx (section 'GPIO'):
The Open Sound Control (OSC) settings should be as followed:
Input: ip-address:port (example 192.168.1.149:9000)
Have you tried resetting your OCS connection within ProppFrexx?
This can be done by opening the Remote Control Monitor (RCM):
- in the Main Mixer Channel click on the RCM button
- in the popup window make a double-click on the text/icon next to 'OSC Server:' to start or stop it
- it should show Online/Offline respectively
- the running icon should be green
After that fully close your TouchOSC application on your iPad and start it again!
Farbo
Post by Farbo »
Unfortunately, for androids there is no way how to transfer layout to mobile phone. :-( Or is it?
Peter
Farbo
Post by Farbo »
Yes. :-( Is there a way how to trasfer ipad version of template into android, i.e. samsung galaxy s3 phone or do I have to do it from scratch in touch OSC editor?
Peter
As said, not that I know of - but I guess that is more a question you would have to ask the 'TouchOSC' people.
Not that I know of - but that is more related to the 'TouchOSC' implementation I guess.
Joche
Post by Joche »
I have tried and tried but I can't get it to work correctly.
The Main and Mixers-screens are working OK. But something goes wrong on the cartwall-screens....
It is possible to play the jingles, to activate PFL and LOOP, but no labels and no LED:s work.
I am using the latest version of TouchOSC on an iPad Air and the latest version of ProppFrexx in Win7.
Joche
Post by Joche »
Thanks. :) Now the names of the jingles are correct, but the "LEDs" still doin't work. Any idea?
