fade (mix) after overlay to playlist
This forum is unmoderated!
Re: fade (mix) after overlay to playlist
See my answers above. Without knowing your settings I cannot know.
Also, why don’t you put your questions to the Q&A topic, as this topics here are not really intended for specific questions. You need to register as a user in order to see all topics!
Also provide your last track of your overlay to look at this one!
In your sound example it also seems, that you are playing music with an overlay?
Can you please also post what exactly you are playing via an overlay scheduler - e.g. provide the screenshot of the overlay entry as well as probably the full playlist which you have scheduled.
From the sound snippet it sounds like the music stops pre-maturely all of a sudden...which is definitly not normal.
As said above you must probably adjust our Mix Out option of the overlay.
Note, that ONLY a negative 'Mix Out' value does a fade-out of the overlay - any other Mix Out value lets the overlay play out til its end.
So try a Mix Out value of e.g. -5000 in your case to perform a cross-fade.
