maniual changes RVT
Re: maniual changes RVT
Also try to locate your .Net Framework installation and try to repair it.
Can you further make the following tests (which will help me narrow doen your issue):
a) when you do a reinstallation, also make sure to remove all *.layout files from your existing ProppFrexx AppUserData folder!
b) can you check, if Drag&Drop (moving nodes) is possible within the Trackboard window?
c) can you check, if it is possible to drag a track from the Find or the Explorer window and drop it to the playlist?
