DJ-Players now auto-size to fill the entire playlist
Re: DJ-Players now auto-size to fill the entire playlist
No, that is not the reason, see here:
Same as before: 1 monitor, 24 inch (1920x1080) - 2 DJ-Player - sized correctly with v4.0.3.3.
XTended
Post by XTended »
Interesting answer..
I only try to think with you, Bernd, it's not a personal attack.
So there must be a difference between your settings and mine.
What could it be?
Which settings do you use for "Look and Feel"?
Of course no, I also just try to find the differences ;-)
Look and Feel: all defaults.
Have you trfied to delete/reset your .layout file?
XTended
Post by XTended »
Ribbon style = default
Skin style = dark room (there is no default in it)
I just did a reset of the layout, but still the same issue.
Maybe deleting of the .layout files is better, but do I need to delete them all?
Maybe we should do a TeamViewer session tomorrow... as here also the DarkRoom skin works well (default is MetropolisDark).
XTended
Post by XTended »
That's OK Bernd, you already got details in Teamviewer Chat.
XTended
Post by XTended »
Thanks for the new update and all your fast support; good work Bernd!
No, I never save any customer details for security and data protection rules, can you (re)send me thius via eMail or PM here...?!
