PF v3 on air expired
AladnaFm
Re: PF v3 on air expired
Post by AladnaFm »
Deleted the 'Beheer' account completly, so only left with the AladnaFM account.
I have a clock syncing software on pc that is correcting the time every 15 minutes. I've deleted that also.
When trying to re- register PF it first said 14 days left, when i pressed register again suddenly it was 7 days left, and when i pressed again it was in demo modus.
But still no luck register PF! It keeps saying 'You registration data is invalid'
I've send you some private information about the keys and registry in a pb. Maybe you could take a look at that if it has any use?
14 days.jpg (35.15 KiB) Viewed 6572 times
When I pressed register again:
AladnaFm
Post by AladnaFm »
Found it! Maybe!
Ident-number provided in the mail 2 years ago is only 1 character different than the one PF is giving me now.
I send you both ident/numbers by pb!
Update.....PROBLEM SOLVED! CASE CLOSED!
Are you back dating your system date time ? or any other software is changing the computer time?
Or are you probably again changing between 2 parallel running ProppFrexx instances on the same machine with 2 different user accounts?
Note, that if such a 'hack' is detected by ProppFrexx, you only have these X days left...so you probably want to re-register AGAIN, like before (see above). And then then try to run ProppFrexx ONLY on one use account and not on 2 in parallel !
May be this is what you have changed recently?
As it was running without any issues since 2 year... and as said, something must have changed to cause this trouble.
Then you did not provide the correct registration information.
Make sure the customer name, email, serial, registration key is EXACTLY provided as given in the registration mail.
No space before or after, case sensitive letters etc.
And check your Ident-Number again! And make sure, that ProppFrex is NOT running anymore on the other user account session!
AS said, you would be the first customer where it would not work ;-)
What is your system's date-time - is that maybe jumping around or totally incorrect?
Is an unattended Windows update or any other software update happening, which scrambles things on your PC?
Something must go wrong on your machine - yes!
