Airlite condition check channel source selector
andrerotgans
Re: Airlite condition check channel source selector
Post by andrerotgans »
Do you want me to test some other macros or will this (those three) do for now?
By the way, just as with the sourcesel macro, in the monitoring tool from the GPI-client, the status change from the Airlite is coming in ok. You see it changing from 1 to 0. So, PFOA is detecting a status change from the Airlite for this particular function when I press it on the Airlite (as shown in the video in the earlier post)
Best regards,
André
No, I need to clarify this with D&R - may be I am going to write you a little test app to see what is failing.
Please check the latest v4.0.1.25 update - I hope this is now all working for you.
barelds
Post by barelds »
Unfortunately the problem is still there in the latest version.
Greets,
Harm Jan.
As said then we need to check with D&R. The code is the same as in the test app I send you.
barelds
Post by barelds »
But in the test app everything works fine and in PFOA I have to stop and start the gpio client first before the change takes place.
But it is 100% the exact same code. There is no code in line which I might change or optimize.
So I can only assume that in a real live environment other arriving messages overwrite each other.
In the test app we only tested exactly that certain message.
I am as clueless as you - that's why we need to contact D&R for help.
barelds
Post by barelds »
Okay thank you I understand. Hope they have a solution, it's a very strange issue we have here.
Finally fixed in the latest v4.0.1.32 !
