Same FTE loaded into Deck A and B
Re: Same FTE loaded into Deck A and B
Yes, that is what I also find puzzling - there must be something else going wrong.
But, lets wait until you send me the files, may be I can find something...
Looks all fine so far.
Really hard to say what might cause such issue.
I also never heard about an issue with unloading a track! I could not even think of anything which might cause this and no other user ever reported something like this. Maybe that audio file is corrupt?
So that all sounds really weird to me, but YES, a constant 60% CPU load sounds definitely ways too high!
So why is it so high? Are you using tons of DSPs/VSTs? Or is your system so slow/old?
Can you tell me where the track in player C is comming from ?
It seems not contained in the playlist?!
You also mentioned, that the FTE's are set to StartType = Manual ...
... so could that be the issue here?
As 'Manual' mean you have to start to manually!
Now I am even more lost - sorry ;-)
Before you said, it happens to FTEs (Fix Time Elements). But that track is for sure not an FTE...
Are you sure no one triggered that manually?!
However, in order to figure out what is going on, on your machine, please do enable the 'Debug Logging' option i the general settings, section 'More Stuff'.
This will create a file called "Debug_*.log" within your ProppFrexx AppUserData folder. Once the issue happens again, please send me that file with the related time or track name where this happens...
I assume, that else I am unable to find your root cause.
Can you please so far also send me your above "playbackhistory.pfp" file.
Thanks
ExIT_FM
Post by ExIT_FM »
I did not send anything because there's no debug log file in my PFOA app data folder. (Checkbox is checked in the preferences)
And since I rescheduled my overlays, the issue disappeared. I found some overlays was set to Manual Playout + AsPlaylistInsert option. If I'm right that means, every overlay entry should be played manually but the first entry starts automatically. One of my overlays contains only one entry, I think this caused the issue. The program played the first entry, but didn't played the next entry in the playlist. Anyway, at the moment the issue is solved.
Thanks for the support!
You wanted to send me the log and playlist files... but so far I did not receive anything.
Is the issue already solved?
