${ramptimems}
djbony
Re: ${ramptimems}
Post by djbony »
any news?
Peter
Re: ${ramptimems}
A v4.0.1.31-beta is available containing the new macros ${ramptimems}, ${ramp2timems} and ${outrotimems}.
So you might “Check for updates…”
djbony
Re: ${ramptimems}
Post by djbony »
Thank you! Super
Re: ${ramptimems}
No, not yet, else I would have let you known here ;-)
As said, you might also ask PowerGold to support the existing ${ramptime} macro format in between.
djbony
Re: ${ramptimems}
Post by djbony »
I'm upgraded to the newest version and I couldn't find ${ramptimems} macro... Where's the problem? :(
Re: ${ramptimems}
Find where - just use it or look to the user manual...
djbony
Re: ${ramptimems}
Post by djbony »
If I put the macro to the ProppFrexx.exportformats (<field name="Ramp" start="0" length="0" align="left" pad=" ">${ramptimems}</field>) in .psv file is empty string...
Re: ${ramptimems}
That should actually work...
I just tested the ${ramptimems} macro in the latest v4.0.1.32 and it works perfectly fine!
So maybe your media library entry did not contain a Ramp cue point?!
djbony
Re: ${ramptimems}
Post by djbony »
And it will be supported? ;)
Re: ${ramptimems}
I'll take a look - but in the meantime, please ask PowerGold to support the standard format!
