Cardwall: fade out current playing entry
Re: Cardwall: fade out current playing entry
The new v3.0.14.34 contains a new "Stop Others on Play" option for each cart.
This can either be toggled via the Loop button (a 'S' character indicated the Stop others mode) or via the Cart's context menu.
dotinga00
Post by dotinga00 »
radio42 wrote:The new v3.0.14.34 contains a new "Stop Others on Play" option for each cart.
Bernd,
There is a little error: the settings won't save, although i save the cartwall.... So every reboot i have to edit the settings again...
regards,
marcel
What type is the cartwall of (playlist based or folder based)?
If it a playlist based media lib it should actually save when you save the cartwall.
However, internally a track settings (option) is used to implement the feature for a cartwall track.
As such, when using a folder based media lib, you might open the TAG Editor after setting the 'Stop Others on Play' option for the respective track (i.e. use the context menu) and then press the 'Save Meta Data TAG' button to persistently save the option for that audio file.
dotinga00
Post by dotinga00 »
radio42 wrote:What type is the cartwall of (playlist based or folder based)?
Hi Bernd.
I'm not sure about your question (playlist or folder based). I guess i use the playlist based. I have done several things to try to save it:
  • Main, save cartwall libraries
    Edit the Cartwall (as a playlist), then save the cartwall libraries
    Your solution (TAG editor). If i do this, and press save the windows close (as expected), but immediatly the stop other on play is deactivated again (the "S" sign in the cartwall disappears).
Uhhh help? :roll:
Marcel
I will take a closer look!
But probably next year ;-)
dotinga00
Post by dotinga00 »
radio42 wrote:I will take a closer look!
Of course, there is no rush. I can demonstrate it like this... Thanks for alle and have a good and happy new year!
Marcel
Please check the new v3.0.14.35 it should fix the save issue with the new cartwall 'Stop Others on Play' option!
