Libary mediatype and History
Re: Libary mediatype and History
the history seems to work bader the longer PF is running and working a bit better after restarting
This behaviour would actually explain whatI was already saying...it seems your history settings are not really okay for your use case.
When you (re)start ProppFrexx the Media and Script History might not be reloaded (depending on your settings, e.g. if you didn't activate the 'Keep Song History persistant').
In that case your 'News' tracks might be scheduled due to NOT matching any history.
But after some playouts, your history might 'grow' and more and more tracks might violate your Song History and are as such not scheduled anymore.
Please try the following settings:
a) News Media Library (Default EntryType='News'):
Song History: 2 or 3 (instead of -1)
b) News Script(s):
Song History: 0 (disabled)
c) Global Song History:
Exclude EntryType='News'!
Please check with v3.0.11.00 - it should work with this release.
At least I couldn't reproduce your issue with this version.
Andreas Duswald
Post by Andreas Duswald »
YEEEAAAAAA
It is working again without any fault - and it is reakting korrekt with the history settings as well.
Thank you - Great work - and also the new Layout is very good and after you have found all things, it comes much more easy to handle
Great WORK Bernd
Everything is possible ....
