Program Scheduler
Re: Program Scheduler
I'm deleting the gray program every time again..but still (only in the 10-12 hr scheduled program) it comes back again every day. For example, this is how the scheduler is right now (see attached file).
- scheduler1.gif (247.48 KiB) Viewed 12034 times
rockfiles.nl 110% rock radio!!
the no.1 rock & metal station!!
ProppFrexx wouldn't create scheduler entries by itself!
Are you using the import module (see the Import button in the ribbon above) to import external playlists?
Or are you using the PROGRAM_IMPORT control-command somewhere?
Or is some other app maybe manually accessing the calendar file?
Else, this is impossible - ProppFrexx doesn't automatically create new entries by itself.
Please send me the calendar file to take a look at!
What do you mean with calender file?
The program scheduler is kept as a calendar file.
You find the location of the .calendar file in the general settings, section 'Scripts/Scheduler' - see the field 'Scheduler Calendar'.
Please send me the file given there.
I found the file ans it's called, but it's an .calendar file..How do I send that to you..
Via eMail, via a PM here in the forum or via any link...
Until you send the file, still, please check:
- if you are using the import module (see the Import button in the ribbon above) to import external playlists?
- if you are using the PROGRAM_IMPORT control-command somewhere?
- if another app or instance of PF maybe accessing the calendar file?
I have send you the calandar file to your email adress...
Have you checked:
I'm not using any one of the above.....as I said before. My scheduled program form 20-22 hr gives no problems at all. (with the same settiings as the 10-12 hr scheduled program)..
