Doing the production work remotely
Re: Doing the production work remotely
Can you please tell me how to send the above commands from a slave instance to master ?
I can't find any info on that.
Sure, that is explained here: viewtopic.php?f=9&t=12#p21
I feel so stupid.
I want to update the Additional Script Libraries on a Master PF. This file has been edited from a slave PF.
I 've tried the next commands on slave machine:
EXEC_SEND_TCP ONAIR2:8052|AUTHORIZATION 12345${CRLF}${CRLF}SHOW_ALERT_WINDOW ONLINE|Test that command is working!${CRLF}${CRLF}
It Works.
EXEC_SEND_TCP ONAIR2:8052|AUTHORIZATION 12345${CRLF}${CRLF}MAIN_RELOAD_LIBRARY${CRLF}${CRLF}MAIN_RESCAN_LIBRARY${CRLF}${CRLF}SCHEDULER_REFRESH${CRLF}${CRLF}ADVERTLIB_REFRESH${CRLF}${CRLF}
It does not work
EXEC_SEND_TCP ONAIR2:8052|AUTHORIZATION 12345${CRLF}${CRLF}SCHEDULER_REFRESH${CRLF}${CRLF}
It does not work.
I 've set -globalconfig to a shared drive on both pf instances.
On a second pf instance I add an additional script library.
I check and confirm that the file "ProppFrexx ONAIR.scriptlibs" has the new script.
I issue the above commands but the master pf instance does not update the additional script libraries.
Even of master I tried to run the SCHEDULER_REFRESH command with no luck.
How additional script libraries can be updated on master pf to the updated global "ProppFrexx ONAIR.scriptlibs" file REMOTELY ?
What am I doing wrong ?
If I go to settings and click Rescan/Reload button the file is updated. But can it be done remotely ?
No, you are definitely not!
It is again a couple of dependencies, which might prevent the script reloading...I am afraid.
a) The SCHEDULER_REFRESH command only has an effect if the related calendar has been changed.
or in other words, if the calendar has NOT been changed the command does nothing.
If the calendar would have been changed, it would also reload the media, cartwall and script libs as well and then refresh the scheduler.
b) The MAIN_RELOAD_LIBRARY command would reload the scripts only, if the general setting "also reload Script Libraries" in the section 'Folders/Libraries' is checked!
else it would only reload the media and cartwall libs.
So in your case you need to check the above mentioned "also reload Script Libraries" option.
c) The ADVERTLIB_REFRESH always reloads the entire advert lib.
d) The MAIN_RESCAN_LIBRARY command manually rescans the media and cartwall libs.
So there is currently no direct command to force a reload of the script libs (see answer b).
I might add one in the next release. In the meantime use the option as mentioned in b).
"also reload Script Libraries" was already checked but unfortunately the "Additional Script Libraries" did not rescanned/reloaded (updated to the latest version of "ProppFrexx ONAIR.scriptlibs")
That's strange - I need to check that here...
Please try the following:
EXEC_SEND_TCP ONAIR2:8052|AUTHORIZATION 12345${CRLF}${CRLF}MAIN_RELOAD_LIBRARY ${CRLF}${CRLF}MAIN_RESCAN_LIBRARY ${CRLF}${CRLF}SCHEDULER_REFRESH ${CRLF}${CRLF}ADVERTLIB_REFRESH ${CRLF}${CRLF}
Note the space after each command and the first ${CRLF}! This is actually needed for parameter less commands.
The new v3.0.13.24 now also contains a dedicated "MAIN_RELOAD_SCRIPTLIBRARY" control-command.
